how to tell what 16g turbo u have?
Status
Not open for further replies.
WICKEDTEEN84
44
May 12, 2004
LONGVIEW, Texas
i was just wondering if there is anyway to tell what 16g u have just by looking at it. like what numbers to look for any thing distinguishing about about them
small 16g
big 16g
evo3 16g
how do u tell the difference
On the turbo you will have a set of numbers on it. The first tells what housing it is, if it is a 16g then it will say TDO5H-######. In the spot where those numbers are, the last digits tell what type.
If the last 3 or 4 digits are
420 - Big 16G
520 - Small 16G
1470 - Evo III 16G
:thumb:
That's a good start.
The complete serial numbers should appear like this:
49178 - 01420: Big
49178 - 01520: Small
49178 - 01470: EVO III
As mentioned above, the numbers you're looking for are the 42, 52, or 47. Keep in mind that all bets are off if the wheel has been changed. However if it's a factory piece, those numbers will be valid.
Cheers,
Andy
Status
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
