How to check for bent valves
Lucas03es
285
Jul 28, 2009
Las Vegas, Nevada
When I bought this engine it was still in a car that would start up, but it was idling like crap, and the previous owner said that the valves are probably bent. So I have the motor pulled and the head off, and nothing seems to be too bad. How would I go about making sure that the valves are okay?
Or some Brake clean, after turning the cams to make sure the valve appear to be closed all the way...
I know it's a little late. But, should have done a leak down test first before tearing it apart. Or at least checked if it was in time first.
I just checked all the valves and I didn't get a single leak using carb cleaner :D Thanks guys!
i remember when my timing belt snapped, all of my valves where bent. u keen literally see the bent valves. the best thing you can do is to take it to a machine shop and have them pressure check it.
What if you have no Intake valves bent? But have an exhaust valve bent?
LOL Oh yea, doing a ghetto BLT only covers half the valves. Filling the runners with brake cleaner or gasoline and seeing if it leaks will also work, as mentioned above. Its also possible the valve could leak from carbon build up keeping it from sealing in the CC, try cleaning up the carbon on them as well using oven cleaner.
:dsm:
Just do it the right way and bring it to a machine shop. In CT i think they charge like 45 bucks to check. Better to be safe than sorry. I know I def. dont wana be stranded anywhere LOL.
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
