how much power am i going to be looking at....
awdsmkedu
Jul 11, 2005
brighton, Michigan
i just got dsm link, a 16g ported and polished evo 3 turbo, 850cc injectors and a walbro 255 fuel pump. how much power am i going to be looking at with these upgrade? to the wheels?
please lett me know.
AIM: mntice69
850cc injectors seem like overkill for a 16g.
Anyway, it really does depend alot on tuning, take your time and you could end up anywhere from 240-280
That answer is based on unknown other mods to your car, update your vehicle profile please.
Its not like anyone can just throw out a number withought knowing a few more things. Like what your planning on running for boost. And tuning plays the most important roll.
You can be running a car with the biggest turbo you can fit, and pushing alot of boost, but it doesnt matter if you dont get the right tune.
Get it tuned and go to a dyno. That's the best way. :thumb:
There are too many factors to be taken into account, and nobody likes bench racing.
You're also going to want to do the basic intake mods (filter, IC pipes) and larger exhaust. Otherwise, you're blowing/sucking through a small straw. The backpressure in your exhaust will hurt, and the restriction in your upper IC pipe will make your turbo work harder than it has to limiting how high you can boost without dropping off in efficiency and running into knock problems.
Then you also need a 1g BOV or similar (the stock 2g will leak like a bastard above 12psi boost), a boost gauge, and MBC. You'll need a ported 2g mani or a tubular one with a collector diameter to match your ported evo3 or you'll have a huge step where they mate (your 2g mani is about half the area of the ported turbine housing on your evo3).
You can't just bolt on the turbo, install the injectors, then tune with DSMLink and get what it's capable of without these other mods.
AIM: mntice69
http://dsmtuners.com/tech.php
Doesn't anybody read the tech guide, FAQs, and tech articles before posting? Asking how much horsepower is in a box of parts is like asking what's the temperature of a grapefruit.
