how much boost is too much?
DROPthatCLUTCH
483
4
Feb 21, 2011
Calgary, AB, Canada
hey just wondering, how much boost is too much boost for a stock 1g?
im pretty sure it pushes 7 stock, but im just wondering if id be able to get a bit more out of it?
or should i keep it all stock as a rock?
i would like to get some more boost but i dont wanna be one of those fools who over-boost their talons and blow it up.. haha lemme know
thanks!
Buy a logger, turn up the boost until your injector duty nears 90% under full load or you start to see knock under full load as well, then back it down a couple psi.
If you blow the head gasket out the front of the head, you went too far. LOL
Leave it at stock boost unless you have a way to see your AFR, if you want it to be faster do a blt. Fix every leak you find and you should notice a huge difference.
i have and apexi turbo timer, its shows AFR, battery charge, turbo time, and something else i cant remember right now
Dont go changing boost unless you have a way to control and log it. As well as tune for it. Stock ecu and fuel is good enough for about 2-4 psi higher but you still can run into problems by changing. First thing first is to find a logging and tuning equipment. Then do upgrades such as fuel and boost.
+rep.
    • dsmmario
    • Detail
    • dsmmario
