how much is too much?
customgst
Sep 9, 2012
saginaw, Michigan
So I am in the process of changing my clutch and well when i pulled the intake pipe off from the box to the turbo there was some oil in it, not a lot just a little bit. There is no shaft play at all up or down nor side to side.. is this a big problem? Just want to know if its common or not.:confused:
more then likely your pulling in some oil from your valve cover where it uses vacuum from your intake pipe, this isn't that big of a deal. You can just buy a catch can, or a fuel filter to get rid of this.
New cars do it, too. ;) Though the fuel filter is "classic" DSM DIY, go with a decent catch can.
Thank you. That is what i wanted to hear..now about the catch can hook up, would i go about doing this..never put one in before, didnt think they were a big deal really.
You can google search it just type in " dsm catch can setup" or search on here there is countless threads on it, basically all you want to do is get a good catch can like Lando pointed out, setup a line coming out of the valve to the can then a line from the can to your intake. nothing to complicated
The shaft play of a turbo can go up ad down slightly but if it goes in and out Front to Back the Rear seal could be blown. bet check that before u waste your time GOOGLE you tube proper turbo check
i take it you didnt read it right, there is zero shaft play in any direction. if a mod will please mark this resolved id like that, as i dont know how to or if i can.
