2G Horn doesn’t stop blowing after airbag deployment
James_dsm
34
3
Jun 25, 2020
Littlerock, California
My srs light had came on 2 days prior; having time I checked it out yesterday. I disconnected the battery and waited about 10 minutes to start unbolting everything. Took off driver side airbag with no issues, disconnected everything one by one with patience. When that was off I switched to the passenger side. Removed the glovebox to gain access to the red wire with the green safety clip, out of curiosity I disconnected and reconnected, the green clipped was snug. I reconnected everything in order from where I started then reconnected the battery. The horn wouldn’t stop blowing when I hooked up the battery. I thought it was okay to remove the relay for the horn temporarily, so I did. I turned on the car once more and BOOM the passenger airbag deployed, but not the driver side. Horn still doesn’t stop honking when hooked up. What do I do?
