Dash lights and over heating after blowing sub woofer
leepen
577
10
Dec 17, 2006
Las Vegas, Nevada
Posting this up for a friend
I blew my sub out and 5 mins later The coolant brake and battery light is on and the temp gauge goes above the meter
Fans work, fusses are good, alt is good. Any suggestions are helpful thanks
check the voltage the alt is putting out, when my altenator went out, instead of producing 0 voltage it started full fielding and going up to 18 at some times, when it would go above 14.5v (I believe that was the voltage) all those indicators would come on until the alt's voltage came back down into an acceptable range, changed the alt and then the problem went away, I was running a pretty decent sound system in the car at that time and the factory alt just couldn't handle the load i guess.
He tested it by disconnecting the battery, at that time there was a slight voltage increase
Edit: he has a 2G and the amp has been disconnected
This is not a good test on newer cars, you risk damaging something.
Check the output of the alternator with a multimeter or remove it and bring it somewhere to be tested.
Blurred: that's the next step
Tyrler: he said there was some smoking in the belt area, but the belts stayed on. Thanks everyone
He's at work now, so his replys and solution will be later
I'd have him make sure the belt is spinning. Sounds like something locked up (waterpump or alternator possibly) and the belt is just sitting while the crank spins.
Sure taking off the alter means that is it putting out something, it may just not be enough. I should of specified, Test VOLTAGE. 10 volts will keep the car running just not very well. The engine fans will spin but be weak because they arn't getting full power (my reason for heating up).
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
  • For sale 1g Kiggly Racing 1G 7 Bolt Flex Plate
    Kiggly Racing 1G 7 Bolt Flex Plate $85 + shipping & paypal fees* these are $175 onlineYou...
  • For sale SBC Organic Clutch Disk
    Brand new organic material disc came from the SBC Stage 3 street K05048-SS-O CLUTCH kit, but I...
    • Mahreeoh17
