DJpowerHaus
Banned Member
- 22
- 0
- Nov 22, 2003
Are there any benefits to using the bullseye housing other than having it bolt up? Different A/R... etc. etc.
IPT said:I have chimed in a time or two. I have had an HX-35 for a little over a year now and LOVE it!!. I ran a 7.68 in the 1/8th on pump gas. I get over 20 psi of boost under 4k. I have not got it to the dyno yet. What else do you need to know. Ask away...
Nick
pianoman said:Was this the guy with the HX-40 at 20psi?
Morphius said:1. Can you post a pic?
2. Find out what it'll cost to dyno it locally. (I'll explain later, why)
3. What's keeping you from getting it dynoed?
4. Are you the one on DSMtalk, the supposedly had one installed a year ago?
5. I've read on another board, that someone had issues with surge? How about you? Anything abnormal about the setup that you've heard or experienced?
I agree, it'd be real nice to see some dyno graphs of those that are running them. Afterall, there is a supposed, 6 or 7 people running them. For those that have been posted on Bullseye's site for HP, they should have submitted a graph, right? Can't it be posted?
. IPT said:And I say that because I have stalled my 2G (VERY VERY BAD on the turbo) more than once and have no shaft play and I did that on a garrett that I had once and trashed it out. TRUST me I went through five turbos in one year!!
IPT said:To make the holset compressor wheel and cover work on a garrett center section would not be a easy task. First of all the back size of the compressor cover on the holsets are WAY bigger then the Garrett seal plates. In fact i had to have the seal plate on the holset cut down considerably for the T04B cover to fit.
LAter
IPT said:2)The local cost for dyno time is $125/hr and it is a mustang dyno I believe.
Morphius said:Is this due to compressor surge? or something else?
