HKS bov return hose
97spyder maayng
71
Sep 11, 2004
toronto,
if anyone's installed an HKS SSQV bov on a 2g, theyd notice that the pipe for the bov vacuum hose is too thin, and the bov vacuum hose can easily slide right off.
what's a good way in enlarging the diameter of that pipe or sealing the two together (vacuum hose to bov) without having to worry about any leaks?
thanx
here's what i did: On the stock 2G bov their is a thick rubber gasket sealing it into where it plugs into the UICP I took the gasket off, cut it up a little bit and wrapped it around the HKS's return port, wrapped a little bit of electrical tape around it and used the smaller end of the BOV return line to attach to it. WOrked like a charm :)
genius...dirt cheap :thumb: (free actually) and makes complete sence, ill try it2morro morning,
thanx
thanx
No problem :) It'll work, the tube will never have to hold any pressure so it wont be a problem.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
