Hit a speed bump, car shorted out and died! Help!
98gst14b
453
Jan 24, 2006
Keys, Florida
Car has been perfectly fine for as long as I remember and for some reason, last week I go over a speed bump and as soon as the back wheels came off the pump everything shutoff and car died. Ign. Sw. Motor fuse was blown, so I replaced it, immediatly blew again. so I stuck an ohm meter between the blade faceing the rear of the car and chassis ground and meter reads 0.0 ohms. I pulled all the fuses out everywhere, still reads 0.0 I went thru my wire diagrams in my manual but it does me no good, I need to know where this white wire coming out of the fuse box goes? It is shorted out and I cant find out where. :( can anyone help? I had to tow the car and its just dead in the driveway.
Ended up tracing it further to the black/ why stripe comming out of the ignition switch shorted, anyone know where that goes?
I need some sort of diagram so I can eliminate the sources one by one.
The problem I have is all the schematics I see are for lights I need one for the black/white wire and ignition switch system. I found a shorted black/White in the blue connector behind the stereo where does this plug go?
Found it!!! apparently when the car bucked the engine tilted back and pushed the condenser up against the compressor line and crammed the the condensor into the intake manifold, forcing the non-insulated wire out of the epoxy sealing the condensor and against the manifold. Heres a pic. A huge thank you to rally for helping me out :thumb:
  • For sale 1g 1g FWD 3speed design scattershield
    1g fwd shield
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $35 each. Message 702-741-6987.
  • For sale 650cc injectors
    Fic 650cc injectors $70 plus shipping and pp fees
    • Fully built dsm
  • For sale Cts-v calipers+rotors+adapters
    1g/2g CTS-V calipers cobra 12.99” and ctsv adapters, $650 plus shipping&pp fees text me if you...
    • Fully built dsm
  • For sale 2g turbo ecu’s
    $120 each +shipping&pp fees.
    • Fully built dsm
