Car freaking out.
FearlessNick
756
Jan 3, 2011
Casa Grande, Arizona
I have a 98 Eclipse RS. Don't know what started these problems. But they happen about once a day.
I will give you today's story. Driving from Walmart to go get gas. Everything is running fine. Pull up, usually leave my ignition to the accessory click. Let my stereo play while I'm filling up. Get in my car and start it up. Then my battery light comes on and my deck shuts on and off repeatedly. The gauge cluster flashes to. As well as the RPM's jump around from 1300 to like 500. And also the temp gauge goes up. Right under the high mark.
But I have brand new coolant in it and my oil I just recently changed. My fans do come on. But you can feel the heat off the engine when you open the hood.
Well I left the station and I'm driving down the road. Get to 45 MPH and my seat belt light comes on and my car is beeping at me. This seatbelt light has never came on before. Even with my seat belt off.
Well I put it in to neutral coming up o a light and it goes away.
So now I'm outside my house. Just took out my subs and the wiring and cleaned the terminals on my battery.
All of the body grounds have been shaved down to metal.
Now I'm looking around the engine bay for other grounds and stuff that is corroded.
I have checked all of the wiring for my deck and everything is fine.
Opinions please?
- Nick
Email- [email protected]
Twitter- @FearlessNickCG
Vehicle- 1998 Mitsubishi Eclipse RS
Check the Voltage at the battery when the car is running ? This sounds like symptoms of a loose battery terminal or bad connection but could be a a voltage regulator running wild.
Check your ecu out real quick, see if anything smells a little fishy.
  • Wanted 2g WTB - 2G Cluster
    Looking for a donor 2G cluster for a project.
    • rwmagee90
  • For sale 1g 1g FWD 3speed design scattershield
    1g fwd shield
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $35 each. Message 702-741-6987.
  • For sale 650cc injectors
    Fic 650cc injectors $70 plus shipping and pp fees
    • Fully built dsm
  • For sale Cts-v calipers+rotors+adapters
    1g/2g CTS-V calipers cobra 12.99” and ctsv adapters, $650 plus shipping&pp fees text me if you...
    • Fully built dsm
