High RPM
rw87tt
66
Jul 13, 2008
Houston, Texas
What causes high RPM at start up? After which it quickly comes down and idles normally. Problem is it makes the lifters rattle and makes other noises untill it builds oil pressure.
Thanks for the replys. Steve, If I were to guess. It's probably no more than 2000 RPM. It quickly comes down. It just makes engine stuff rattle. It doesn't rattle all the time. Probably half the time and the severity varies. I'll pay closer attention to the rpm when I start it up. Thanks a bunch for any feed back.
In cold(er) weather on starts my RPMs would shoot up to 2500, pause, then drop significantly to around 500 at the lowest and cause the engine to rattle like it was about to stall. The ECU would compensate and it would normalize, then drive normally.
Check all the vacuum hoses and made sure everything was connected tight. There could be a small vacuum leak. I secured my hose connections, seafoamed, and changed oil. The combination of the three seems to have fixed this. Which helped the most I'm not sure.
