High impedance injectors
mitsu_matt
214
Nov 7, 2005
Lyon Township, Michigan
ok, I had my 2G in a local shop and they installed MWR 630cc high impedance injectors, narrow body. When they installed them they cut the wires to the resistor box. My question is will these injectors work well or should I go back to low impedance injectors?
They will work but it's better to stay away from the Honda shops with your DSM.
The low impedance injectors generally have less deadtime than the high impedance versions.
Rather than hack up your wiring they should have made up a connector to replace the resistor pack so you could switch when you find the 630cc injectors too small.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
