hid light not working
2-fast
Oct 18, 2009
fresno, California
hi i have a 99 gst spyder and i was just wondering why HID kit won't work on my car it's just the plug and play with no harness...i need help
This is a very common issue. Our headlight connectors are inverted from the standard car. So in lamins terms, our positive is everyone else's negative.
How you should fix it - unplug your HID connector from the factory plug for the light bulb, and flip it, and then plug it in again. If this doesn't work then you have a bad ballistic or a bad bulb.
+1. youve got to FLIP the connector the opposite way that its KEYED to fit at the back of the light.
:dsm:
Hook the positive to the power wire at the light connector, and hook the ground directly to your bumper bar or to the core support.
I didn't want to follow the directions at first either, but for some reason it makes a difference.
my lights right now dim out everytime it's at low rpm but when i rev up it light up brighter, does that mean there isn't enough voltage coming through?
