2G Here’s how to wire the horn to work with the Momo Steering Wheel & Hub.
Hello fellow DSM folks. I wanted to post this thread to show how to wire the horn with an aftermarket steering wheel without getting the wires all tangled up inside the hub. Hope this helps other people out with the photos and video I took!
Tools needed :
-18 AWG stranded Wire
-Heat Shrink (optional)
-Heat Gun (optional)
-Wire strippers & crimpers or solder gun (whatever you prefer)
-Butt Connectors
-Ring Terminals
-Female pin terminal (get the ones with a rubber protection on it, so if it touches anything the horn won’t go off)
-Hose clamp
1. Remove the steering wheel (optional) (find it easier with it off since it’s not in the way)
2. Remove the steering column. (2 or 3 screws underneath the column.)
3. Find your horn connector. (Mine was green and red) (Extend it to reach if you need to)
4. Cut one of the hose clamps and make a little hole in it for a small screw to fit through and put your ring terminal in. I screwed it into one of the open holes in the white plastic piece.
5. Bend the clamp to ensure it stays touching the bronze piece on the hub.
6. My hub had a black wire already soldered to that bronze piece on the inside. So that will be your positive on the horn.
7. The ground wire is just grounded to this steering wheel ring. This piece goes behind the steering wheel and it grounds by making contact with the metal hub as soon as you put your steering wheel on.
8. Go ahead and put the steering column and steering wheel back together and connect everything.
9. Press horn to test if it works. Rotate steering wheel all the way to the left and right while pressing the button to ensure it works while rotating.
10. You’re done. Be happy that your horn works now so that you can honk at someone who cuts you off or tries to back into you. Protect the Eclipse!!
Tools needed :
-Butt Connectors
-Ring Terminals
-Hose clamp
Thanks for the write up.just a note that in future for write ups you may find it best to put them in the article section as you are showing people how to do it vs this place for Q&A's. https://www.dsmtuners.com/forum/articles-electrical-wiring.40/
The OEM JDM Evo 4-6 Momo steering wheel is a direct fit for 2G's and it already comes with the factory horn connector. Just a heads up in case anyone is looking for a plug and play OEM Momo steering wheel option. With this route, you won't have cruise control anymore though.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
