help with throttle cable
DARKTSI
51
Oct 15, 2007
ELSINORE, California
ok i finished my 4g63t swap and it started fine and everything but out of no where it revs itself to like 5,000 everytime i start it....i have to push on the throttle cable to lower the revs and turn it off...also my exhaust manifold smokes white smoke crazy after a bit any ideas why?
the cable is to tight the 2 screws that hold it together are tight also but it still revs high i need to unbolt the screws and loosen it up to drop the rpm.....any way to adjust it the biss doesnt really do anything just drops it a little
clean out the throttle body and make sure the butterfly is moving freely and closing all the way in there. The white smoke from the manifold is typical if you just put the motor together if you got any sort of fluids on it. they will burn off after a while.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
