2G Need help with throttle cable
Nate96gst
Aug 28, 2012
Newark, Ohio
Okay so I bought a 98 eclipse gst spyder and I ordered the motor for it since the one that came with the car was blown up. The car didn't come with a throttle cable or a battery tray, are the battery trays the same in all 2g eclipse and will a gs throttle cable work in a gst? Thanks
All 2g dsm's use the same battery tray, the difference is the bracket that holds the actual battery, non turbo 2gs have a shorter bracket while turbo models use a longer bracket. I've seen people use a throttle cable off a non turbo in the turbo models but wouldn't recommend it unless it's the non cruise cable.
