help with map sensor
2g awd dsm
115
Aug 24, 2011
longview, Washington
ok so doing a 6 bolt swap in 95 talon tsi. i hear i hook the map sensor (mdp sensor) into the break booster. heres my question. do i just take the break booster hose off the back of the intake and put a "T" there and hook it back up along with the map (mdp) sensor?
thanks, josh
Yes you can just tee into the brake booster line. Of course install it before the check valve. They don't make adapters no more so you will have to get creative. Since the 2g MDP is a PITA to adapt a hose to, some hyundai (97 sonata that I know of) models come with a MDP sensor that has a provision for the vacuum hose. It is a genuine mitsu part and will plug right in. Here is a link to one to see what it looks like.
2G 6BOLT SWAP ECLIPSE TALON TURBO DSM 4G63 MAP SENSOR | eBay
http://i1006.photobucket.com/albums/af184/mko1234/HPIM0833.jpg
Use one of the nipples on the throttle body.
oh really?? which port would be best suggested to use? and how efficient is it compared to using the brake booster?
i have this for my map sensor just have it laying around the engine bay somewhere for now if that will
work
http://magnusmotorsports.com/products/intake-manifolds/magnus-dsmevo-remote-map-sensor-boss
Connecting to a nipple or the Booster will do the same, But will be better a nipple, which you can use just a hose and connect it from the nipple to the MPD.
so there would be no need for the mdp relocator thing i bought from magnus? LOL and thank for the help all you guys
and any nipple on throttle body will work? for example the "P"
No, It has to be after the EGR, If you do it from the throttle body, it will not detect the EGR, so hook it up from the nipple of the FPR, just T it and it will work.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
