Wiring help for map sensor
boostin90gs
100
Nov 1, 2011
pasco, Washington
So my map sensor pigtails are already wired into my harness, but i wanna run ecmlink plug n play harness. need some help save way and correct way to make it back to stock.
I'm not quiet sure( just did a quick search), but it seems to me like all you need to do is take off the pigtail of the MAP sensor off. Then just reconnect the wires back together by color matching the wires back together. Because it seems to me like the wires on the MAP sensor pigtail are just " T " off, so i wouldn't see why just taking off the pigtail and reconnecting the wire back will change anything except for no pigtail/map sensor signal. The links below should show what wire is what and how they installed the map sensor pigtail.
http://www.dsmtuners.com/forums/newbie-forum/401630-ecmlink-sd-wiring.html
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
