wiring a GM MAP sensor
clipse-T
111
Feb 6, 2006
Tyler, Texas
Well am doing a 6 bolt swap on my 2g. Before the motor was pulled out my CEL had been on due to a MAP sensor malfunction. Am planning to getting a MAP sensor relocation kit for my 1g manifold. Am wondering if i could use a GM 3 bar MAP sensor with the 1g intake manifold with the relocation kit. If so, what all do i need? Currently my setup is tuned with a SAFC and wideband. am planning on going with a DSMlink later down the road..just am just asking if i could wire a GM map sensor on my 2g turbo. Thanks and any help is appreciated!
the gm map woudl not solve your cel problems.
the factory 2g map is actually a manifold differetial pressure sensor, who's function is not to measure airflow, but to verify EGR function.
I believe they make adaptors for the 2g mdp
that allow you to bolt the map to an adaptor that allows you to t it into a plenum source.
The MAP(MDP) isn't actually needed and the CEL affects nothing.
If you get DSMLink down the road you can wire a 3bar into the stock MDP wires and log boost, the how to is on the Link forums.
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
