Help with future mods
Darkmood
43
Sep 10, 2006
Aurora, Colorado
So here are the mods I'm planning on piecing together in the near future. The car will be almost exclusively for track use.
I'll have a 6 bolt block bored .020 over with 8.5:1 forged aluminum pistons.
Ferrea Valves
3rd gen revised lifters
1600cc injectors
Aeromotive A1000 AFPR
Aeromotive High Volume fuel rail
Walbro 255HP Would this be alright or do I need something bigger?
Brian Crower 280 cams
I have a set of Crower valve springs and Ti retainers, but would they be able to hold up with the above mods?
As far as turbo goes I'm looking into a Borg Warner 366-40R would twinscroll or single scroll be a better choice?
Also I need a t4 manifold but am still looking, any choices? I was thinking maybe Full Race
Tial 44mm wastegate
Not sure on a BOV Any suggestions?
I also need suggestions on an o2 housings
Probably an air-to-water intercooler
DSMLink
NGK AFX
All supporting gauges for above mods
ACT 2600 or 2900 with Fidanza flywheel
Also a rebuilt tranny
Custom Exhaust
Car will be run on E-85 and I hope to be able to push around 40psi
Thanks for the help
Right on, Aurora FTW! :rocks:
If you get the Fidanza, please get a scattershield. Its good insurance man, I've seen more than one lightened flywheels disintegrate at high RPM under abuse.
BOV go Tial 50mm is a very popular choice for high boost or the beloved HKS SSQV which is not supposed to leak period. Most people I know say that for the price of a twinscroll there are no real or noticeable benefits, go single IMO, although I can't personally attest to a difference between them.
Thanks for the help guys, the parts ordering should start when I get back from vacation on monday.
Honestly you should get a tial bov,a shearer or full race manifold which they both are good companies.And go twin scroll it spools the turbo faster
That turbo is going to make a lot of power. What kind of tranny are you going to get? I recommend at least a 4 spider gear diff, maybe a welded diff. Also what rpm are you planning to rev too. If its over 8000rpm dont expect to shift that ACT. I see you are on stock rods so I guess you wont be spinning past that.
I think you may want to think of a twin disc setup with the power you may make. Not to mention it will shift a lot better.
Ever think of an HX40. They push a lot of air and spool insanely fast. Also alot cheaper. You could get the whole turbo under $300 and buy a divided manifold that will work nice on the stock housing.
Yeah it's a lot of money. But I got a promotion which will cover most of it LOL
JayRolla: I actually have upgraded Eagle Rods. I just forgot to list them. And as far as transmission goes I'm currently storing up funds for a Premium rebuild from Jack. Twin disc sounds like a good idea.
Any thoughts on o2 housings? I have no idea what to get.
Hey Matt, did you used to be part of the CODSM club? I wonder if we know each other... I lost track of the people I used to talk to on there. My name is Shawn, I'm pretty sure I was the only one rocking a 1G Laser that was modified in Aurora for a while there...in bright red.
On topic, good choice with the recirc. Are you still on the 1G MAF? I didn't see any mention in the first post...
