Help timing issues
96 GSX LOVE
73
Jul 3, 2013
Slansville, West Virginia
Okay so i have a 96 gsx and I just had the motor torn apart. When i put the head back on i followed the correct procedure i aligned my cams with dowel pins straight up pulled them together. Then put the belt on zip tied the belt to the cam gear. Ran it down around my oil pump left the crank pulley a little counterclockwise of the timing mark then put the belt around that and spun the crank just a tad to make tight then around my tensioner. Everything lined up great. Problem i had air blowing out of my intake and air sucking in my intake
I though that, but he says his dowel pins are at 12:00. Only valves that would be open is #4 exhaust. Shouldn't be anything going through the intake. If he's doing a boost leak test, could be going through the PCV valve. Don't know how he got he sucking air into the intake.
My bad guys there is air sucking in the exhaust and air blowing out the intake during cranking the motor.
The only way air can get into an engine is thru the valves. If an exhaust valve is open, air can be sucked past it when the cylinder is on the down stroke. If an intake valve is open, air can blow past the valve on the compression stroke. Either have bent valves or possibly the lifters weren't bled down and is holding the valves off the seat.
Why was the engine torn apart is the first place. Maybe if we knew the original problem we could better diagnose the problem. My money is on bent valves though.
Well i turned it over by hand and it was fine also i did not bleed the lifters because i did not know that you had to do that. The reason the motor was torn apart was to replace the hg and arp studs
It's probably a good idea to either do a clt or pull the head and check those valves. Or your cam timing is off, you didn't accidentally swap cams did you? I just read a post where that happened.
^^^I second this.
Also double check that the hydraulic lash adjusters are seated correctly on the lifters.
Step 1: post a pic of your timing marks on the engine.
Step 2: describe in detail, how you are doing this test. Boost leak test, leak down test? If you cant describe, take a pic.
To answer your question about, "can I swap my cam gears" this really isn't possible if you have a cam angle sensor on the intake cam.
Its a 96 so i do not have the cam angle sensor on the side i have it underneath the cam gear. I cant post pics of my timing marks but its 100 % perfect. I didnt bleed my lifters would that make me bend valves?
It's true stock cams have a slot in the end for cas but someone had posted that they where having a timing issue and the came back and said the cams where accidentally put back in the wrong spot. Not sure how either buy that's what they said, I was really kidding. AutoZone rents clt kits for free just have to put a refundable deposit down.
Okay guys so i figured it out i didnt bleed my lifters. I put my head on then tightened down my cams which pushed the valves open into my 1 and 4 pistons and vent those valves then cranked my motor over and bent my others. Got it all replaced and its good now. Thank you guys for all your help.
