help putting on exhaust manifold?
crfridah
50
Oct 22, 2012
bristol, Connecticut
I have my turbo bolted into the exhaust but I can't seem to get the exhaust manifold to fit does anyone know if there's a special way to do it?
A prybar helps, if you have the one stud sticking up off the turbine housing..Do not attatch the exhaust, that wil make it a tad harder.
OR.You could bolt everything on together..But I do it seperate with a prybar.
It mainly depends on what turbo and manifold you are using.
With a 2G manifold and Mitsu turbo (14b-20G) its easier to put the manifold,turbo,O2 housing on all as one piece, then connect your water and oil lines, then bolt up the downpipe.
I do that backwards too..But I've done it a few times now.LOL
I get the lines hooked up, then everything else.But when I go to put turbo on, water,and oil lines are all attached before i attemp putting car together.
sorry guys it was a a stock manifold on stock turbo but i ended up getting it:D just had to disconnect the dp and push it on
