Help On Intake Pipe Install
KiD_DSM115
286
Jun 10, 2004
Chi-tOwn ChInAtOWn, Illinois
Hey i was lookin gat a hard intake pipe i have its red, no brand...i don't think....however when tryin to install, i noticed that my pipe didnt have the three connection holes for the i believe valve cover, egr? or cas?, then the boost line underneathe, i was thinking of just buying one off ebay that actually has the holes, but i was told i can put a breather filter on the valve one, i dont have a MBC so what can i do about the other TWO CONNECTIONS, thanks again!
It's the PCV - throw a 2 dollar filter on it. Does it have the Recirc "port" or is there anything on it?
Well, the first thing is someone has to put a spell checker in this forum.... JK
1st: On your intake pipe you should have the Recirculate Tube for your BOV.
2nd: 1 hose from your Valve Cover.... install an inline fuel filter as a catch can.
3rd: 1 hose coming from your Charcoal Canister.
4th: 1 Hose coming from your Boost Control Solenoid.
If you're running a MBC, then you won't need this 4th hose.... plug it off at the BCS.
You can run your 3rd hose straigth down out of the can to the road, not wise for emissions testing though.
1st and 2nd lines are obvious....
Good Luck......
The PCV goes to the intake manifold, it's the valve cover that goes to the intake pipe pre-turbo.
BCS - get a MBC.
valve cover - get a breather, catch can, or just run it to the ground
Charcoal Canister - run it to the ground
alright thanks, well yeah i am going to get MBC, filter...but i guess i can run that canister tube to the ground...FOOOCK Emiissinos..i'll jus thor my stock one in before it...also so it would be the same even if i get a injen intake pipe with all THREE CONNECTIONS.....in terms of performance...does it matter? like since i dont have the connections excpet the recir.. for BOV...does it matter as long as i get a filter,MBC...? thanks again
  • Wanted 6 bolt NT water pipe
    • chrisman287
