Logikal
- 54
- 0
- Sep 22, 2004
West Middlesex,
Pennsylvania
Hey guys, as you may know, I have a 2g I bought and destroyed the engine. So I swapped a 6 bolt in.....
I've put 400 miles on it since the swap, it runs excellent, except, it throws engine codes (I keep deleting them...)
First off here is the codes
P0300 Random/Multiple Cylinder Misfire Detected
P0403 EGR Flow Circuit Malfunction
P0443 EVAP Emission Control System C Fault
those are the 3 codes, and sometimes it does the P0300 twice...
First off, Have the emissions solenoids unplugged and off the car.....
the egr, it's on the car, I don't think its hooked up????
Should I get a block off plate???
also my Oxygen sensor is dead, I get .005-.020 readings on the SAFC regardless of throttle position or RPMS.....
(new o2 tomorrow)
My Map Sensor wasn't on, but I just put it on today and hooked a vac line up to it....
I have new NGK plugs and Wires... Power Transistor Module is grounded...
I don't have any clue why it does this, but when it throws the codes its like one cylinder just stops firing... my A/F gauge also lights up a bit even tho my o2 sensor is dead...
It likes to do it between 1800-3400 RPM Misfiring bad.... it's hard to even drive when it misfires like that.....
Any clue anyone??? Is it the o2 sensor dumping an insane amount of fuel??? ( I was averging like 6-10mpg with my MAP unplugged and the bad o2, I plugged the MAP in and haven't seen if it has improved at all)
Any ideas, comments, or clues would be great...
thanks guys
Oh yeah, here's some pics of sunday at the track, and washed and waxed
http://community.webshots.com/album/549970615dlsCAR
(new o2 tomorrow)
thanks guys
