steve
DSM Wiseman
- 17,289
- 3,964
- Feb 3, 2002
St. Charles,
Illinois
I don't know where to set the TPS to a voltage.
From the graphical display hit F9, click continue, scroll down the list of variables and double click TPSVolts, and click OK. That will tell you what is measured but to adjust it you have to rotate the TPS on the Throttle Body. You will likely have to simulate the Idle Position Switch if your wired to get it from the TPS. If it's wired to the 1G IPS on the back side of the TB you may be good.
You can check the IPS operation like you did the TPSVolts but scroll to IdleSW Pin. It looks like your IPS never closes so it will need adjustment or simulation or a 2G TPS.
