05Nissan350z
- 155
- 2
- Oct 23, 2013
Canton,
Ohio
Here's most of whats done to my car. I've tried setting it up like the videos showed, but I still don't think I'm doing something right.. What I do know is it's running like poo, and its killing me not being able to drive it.
1991 Talon awd: Evo 560 injs, 2gmaf, 12v directly to wally 255, 2g pistons, 3g lifters, 1g rods, acl race bearings, polished crank, bored .30 over, 38mm wastegate? its the bigger one plus I ported the **** out of it, mls headgasket, td05h 16g with dual size veins. 2g intake elbow, supra smic, 2.5" intake piping, ported compressor housing, smoothed all intake/ exhaust ports no emissions crap b/s delete p/s delete, ac delete headbolts torqued to 100lbs, 2.5-3" exhaust. port matched all gaskets.
. how do you recommend to check it to make sure its ok?
. And Type1 im not running SD. I bought link off of someone on here who was running SD. I thought I had turned everything off for it? I really have no idea what im doing with this at all. I've watched videos thousands of times and im still lost... Also I have a wideband uego, and it's wired into the ecu.
) to understand ecmlink better:
