ECMlink Stock to Modded: Can you help me get it running right?
b17tuner
232
Nov 9, 2003
Toledo, Ohio
1995 :talon: Talon TSi background
6 bolt engine with 1g intake manifold and full OEM timing belt job
Turbonetics RS49t 50 trim turbo internally gated
NGK BPR7ES w/Magnacores
Thermal 3" turboback exhaust w/testpipe
Busher Bar and Plate Street FMIC 2.5" piping
Greddy Type-S
Boost, EGT, and Fuel pressure gauges all in car
SBR 3500 clutch
ACT Street-lite flywheel with new OEM bolts and loctite
B&M LSD Insert
Tuning setup
Walbaro 255HP Fuel pump
PTE 680cc Injectors
Full Throttle AFPR -Where should the screw about be for 43.5psi?
GM 3" MAF-T setup -Is it working correctly? How to use this?
DSM Link w/slow laptop Lots-o-help needed.
Now I just put all of these below items into the car so it pretty much went from stock to 300+fwhp form. Ripped it all apart and installed them all at once. I am now at a point were I feel like I don't know what I'm doing and to speed my trail and error process up I search and I am posting this. I thank all those in advance that bring me any sort of knowledge.
So far the car starts up and idles at 2500 pretty smoothly. When it does drop below 2500 it's rough, and sometimes misses when I rev it up. I'm not driving it because I haven't finished refinishing my wheels silver.
Your input is greatly needed and appreciated!
My first question is, Is there a way to get the car running decently before driving and putting a load on the engine?
What should be my first steps into getting the car running right before I start doing pulls?
-Setting fuel pressure to 43.5psi, 3ish km/cm2 on my Greddy fp gauge?
-Should I have to check the timing? Links on this?
-How do I do that on the 4g63? What should it be at?
-How do I check the timing on DSMlink and where should it be under different conditions?
-How should the fuel be tuned? What settings for what conditions?
-I think the MAF-T is set for stock settings. Is there anyway to know if it's working correctly? I'm getting at 2200-2500 rpms (my current idle no load) 9-10 gps on DSMlink.
I know these are dumb and basic questions but it's more of a double check and second opinion on what I'm looking at doing because I have read on how to tune, but there isn't to much on getting it running in good condition first. Thank you guys so much if college wasn't eating all my money I would be pay-palling you guys I really appreciate your input.
680s without setting the MAF-T to read the 680s properly. What are your settings?
Without something controlling those injectors, and the obviously increased amount of air your moving into the engine your asking for trouble.
Wow, never mind my question was answered elsewhere. Neither of you read what I thought was a decent post. Since I got help elsewhere I will post for you that don't know what I have found.
You don't set MAF-T's up for 680's when you have DSMlink and I have a MAF-T to read my 3" GM MAF that allows me to bring in more and and move more air making me more power.
What I would do first:
1. Get the MAFT out of there and replace the 2G stock MAS. At least for now.
2. Read up on how to set your global and deadtime adjustments correctly and follow that procedure.
3. Eliminate any boost leaks.
4. Make sure your base timing is correct and set your idle correctly.
5. Get a fuel pressure gauge and use it to set your fuel pressure correctly.
-Thanks to Greenstreak!
Thanks for taking the time to post though!
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
