help idle gurus!!
gsxrmel
Jan 11, 2008
Spain, Missouri
Hello I have a problem with my idle I finished my engine rebuild 2.3 2g 7 bolt turbo Holset hx40 with bep housing these are other modifications:
Gsx 1998 2GB
1998 ECU
1.9c Ceddy bigs mod maps
comp stage 2 cams
2.3 stroker
hx40 turbo
ported stock manifold
Gredy type rs bov recirculated
o2 with 38mm tial pr
fic 1050cc inyectors
walbro 255
fpr fuel lab
slowboyracing short route FMIC
aem wb
the problem is the following
my idle is stable but stopped when i shifting mi and the rpm lower the car stoped
i can see in the wb that when the car decelerate the wb red --- but when it comes to idle just then change to 10.2 to 10.1 and then also up 7.14 5.15 idle
i check boost leak
o2 change
check tps and adjust
check and change new isc
change the throttle body
I do not know where to go to solve the problem
thanks for your help
i chech every steps and nothing :(:( my idle is fine when the car is stoped only have the problem when it is run and shifting.
What throttle body? Which tps?
When I had issues with my car dying it was because my idle switch didn't work. After being oblivious to the cause for years I learned about the necessity and fixed it really easily in DSMlink by using the simulate Idle Switch function. Is your idle switch functioning?
Your symptoms match this scenario pretty well.
yes is funtioning well i check this with the evoscan option and i set the rpm at 750 rpm
the engine stall only with the load 3000 4000 5000 rpm
the throtle body is a stock 98 i check today now boost leak and nothing mi idle is -16 and deceleration -21 in idle stall only with load if dont pass 3000 rpm idle down fine but in load he idle stall and whe wastegate mark 10.0 :(
helppp please!!
