2G Help with IDLE
ac1234
56
Jan 30, 2010
Houston, Texas
Hi There!!! I need some help with my eclipse 1995 gst. The car revs goes up to 3500 or more and never goes down. I replaced already the maf sensor, throttle body and minor things but I cant figured out. I need some help please. Please email me at [email protected].
This is my first post and I dont know if I posted in the right place. Thanks.
I had this same problem with my second Talon, Christine. It was the idle air control valve, which sits on the back of the throttle body if I'm remembering correctly. It had gotten stuck and it was idling at 2500 rpms and would climb when in park.
I just replaced the ISC and still doing the same. Now it happens after 10 minutes of the car being on. Im loosing my head with this 2g. About to send it to the junk yard. Anyone around the Houston, Texas area that can help. Thanks.
The EGR valve is basically directly under the throttle body, a little lower than the ISC and farther in toward the middle of the engine bay. Looking from the passenger side of the car, you should be able to see it mounted to the manifold under the throttle body.
wow i have the same issue I've replaced every sensor besides throttle sensor and it still happens,all new gasketsmnew water pump fuel pump fuel filter gas tank fuel lines,fans,new used motor from a salvage and after 10 min the darn thing revs up super high and shuts off even driving it and changingg gears it'll just die LOL its insane i know how ac1234 feels its been my project car for a year and a half
if u found out what needed to be replaced email me plz
[email protected]
When did this start? Was it fine yesterday?(meaning it came from nowhere) did you just fix something this started?
I had been trying to find the solution for this like for a month!!! I believe that a guy that was working in my car did something wrong because he wants the car. The car was fine till the day that he knew that I was leaving for the Army!!! Im so desperate with all of this!!
[email protected]
Believe me, I let you know!!! But I dont see the exit for this. I spent a lot of money already trying to fix it!!!
Im still thinking about this. Last time that a person worked in my car was installing an apexi afc. Did you think that can be that is not working properly?? I remembered that he told me that I cant remove the AFC because something with the ECU, I cant remember so well.
yeah I've done replaced everything some ppl say re place the throttle position sensor but idk i only have 100 on amazon n they carry my parts
I just got the problem with the car. It was the Apexi AFC, I unplugged it and idle ok, I plugged it back and the revs went high again. Im so glad that we can figured this thing out. Thanks everybody for the help and the advises!!!
