Help identify this 16g turbo!
awdsm drft
257
Dec 11, 2003
None, Louisiana
Which 16g is this turbo?
Also are there any other parts im going to need when installing it?
God i feel like such a n00b.
I cant read the housing numbers. The EVO3 16G, and i think the big 16G have the TD05H housings, while the regular and small have the TD05.
I dont know too much about turbos by looking at them, but i think i'm right with that. If anyone else knows feel free to correct me.
Im pretty sure the 14b, big/small/evo 16g alll use the tdo5h compressor housing. Only way to tell the difference between the big/small 16g is to measure the compressor wheel. The evo has a different exhuast housing the all the rest. Hope that helps.
That's a big 16g turbo. Check out www.slowboyracing.com thier big 16g looks exactly the same including the N on the wastegate.
You should at least try to find the answer on your own before posting incredibly easy questions like that.
Wrong. Big 16g's and small 16g's have exactly the same housings. You need to measure the compressor exducer diameter. Check out the vfaq. I know it says what to measure and what the sizes are cuz I had to do that recently. There is NO way to tell the different between a big and a small without measuring.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
