HELP! I need recirculation
trbotaln
633
9
Sep 7, 2004
hidden hills, California
whats up guys,
I got a problem. I finished making my upper intercooler pipe and my BOV ended up at a slightly different angle then it was before. The problem is that my recirculation tube does fit right anymore so I was wondering if you guys know of some kind of pre-bent rubber hose that would work well so I don't have to re-weld the BOV flange and do it over. I have looked at home depot and some autoparts stores for something like heater hose, but I have had no luck. Please help! :cry:
if your old hose is anything like the new set-up... just take it into autozone and compare hoses. or try buying a longer hose and cutting it. i don't know about getting a "custom" hose, maybe you could find a hose, heat it and bend it how you need?
i went through the same problem and couldn't make anything work. maybe just reweld your flange, so it will work.
Find a parts shop that'll let you nose through their heater hose assortments. Remember the shape is more important than the length. Bend up a piece of coat hangar or welding rod to the right shape and start comparing. Something's bound to fit.
thanx guys, I will try a few more auto parts stores and see if I can nose around in the back and look at their heater hoses. Other wise I will have to re-weld the flange :cry:
you should definitly be able to find a hose for that!!
