**HELP**Gas/fuel in vapor line **HELP**
MyFirst2gdsmgsx
Mar 11, 2020
Philadelphia, Pennsylvania
Hi all,
Would anyone know what would cause gas to be in the charcoal canister line? Correct me if I'm wrong it should only have vapors in these lines right? Just bought the car and previous owner did fuel pump, adjustable fuel pressure regular, injectors...idk if hoses/lines got mixed up. The charcoal canister is filled with gas and leaks a shit ton for now I just bypass the line under the radiator by looping the hose back into the other line, should I just delete it? If so could someone direct me to a good post to follow. Any help is appreciated thanks.
*Edit*
Also is has a P1105 code "Fuel pressure solenoid circuit fault" could that be caused by the adjustable fuel pressure regulator? Thanks again
Topping off your gas tank can water log the charcoal canister, once that happens it stays that way for a long time, that might have been what happened at one time, or there is a general vent issue on the fuel tank causing fuel to back up into that canister.
