Fuel Line help
94EclipseGST
334
Sep 1, 2003
Des Plaines, Illinois
Okay, before I installed my Walbro 255, I hooked up an MSD inline fuel pump. To do this the easy way, I cut into the line that goes from the fuel filter to the fuel rail. How that I have removed that fuel pump, I put plastic adapter between the space where I cut the line. It's working okay, but I want to replace this line. Any idea on what I can use to replace this? Recommended websites to purchase the parts?
Thanks,
Slowboy has a -6AN fuel rail inlet adapter... you could:
- Run a -6AN SS braided line to an AN fuel filter, then more SS line back to the tank, OR
- Run it back to an AN fuel filter, then use an AN adapter with your stock lines.
Either way, try to get rid of that restrictive stock POS filter.
Thanks,
This is kind of hard to read. Are you saying that you have an inline pump and a walbro 255 intank pump?
Or is the MSD this a fuel filter?
Your OEM fuel line from the filter to the rail is just a rubber hose. Go to the car store and get some more rubber hose.
If you want to replace the line that goes from the fuel filter to the rail.
autoalchemy sells a kit.
rjgeiger, I no longer have the inline pump--I took it out when I installed the Walbro.
L2RTSiAWD, you hit the nail on the head. I only want to change the line from the filter to the fuel rail.
Thanks, guys.
