Help! FIAV bypass, alternative solution.
DSMDEMON93
319
Feb 18, 2009
San Jose, California
Hey tuners,
I was completing the task of bypassing the FIAV unit, by removing the freeze plug on the housing and turning the spring cap to bottom out the plunger.
Here's the issue. I broke the notches to turn the valve.
My question is, with the screw broken, can I use a metal
Epoxy to just cover up the passage? So that way, plunger can kind of move, but air won't travel to the TB. I don't mind if it's permanent, I just want it done the "quick and dirty" way to get rolling again. Let me know guys and gals! Thanks!
