Help: Best Valve Springs?
1gDSM4g63
1,808
14
Aug 28, 2007
San Jose, California
I'm having a mass confusing look at all the specs from different valve spring sets. They are all different except for the rate (lb/in). Does the higher the rate mean it is better and capable of redlining even higher? I'm confused, that mustn't be the case. The Ferrea High Pressure Dual springs is $250+ more then the Supertech High Tension Dual springs, but has a lot lower rating!
Supertech High Tension Dual: 426.7 lb/in
Supertech Dual: 317.5 lb/in
Supertech: 266.7 lb/in
Manley Dual: 359 lb/in
Manley: 294 lb/in
Ferrea Beehive: 342 lb/in
Ferrea High Pressure Dual: 305 lb/in
Ferrea Dual: 254 lb/in
Kiggly Beehive: 325 lb/in
If you are running or plan to run beefier cams a set of titanium ferrea valve springs should do it. I have never heard anything bad of them so i'd say go with it. And as for the higher the rate/ higher redline, i think you answered your own question.
If you want the best of the best go with the kiggly beehive springs. They will handle any rpm you want to through at them and last a long time not to mention they are still single springs which are a lot less harsh on the valvetrain like dual spring. But they are expensive at $450 a set.
Beehive is the way to go!!
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/NskusJdk5Qs&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/NskusJdk5Qs&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Another good video:
YouTube - Bee-Hive Springs
Im looking into kiggly beehives and I was going to pair them up with some FP2x or FP3x cams but now I saw the Kelford 272's and those are looking really promising going off of these dyno tests... Ams Evo Cam Test - evolutionm.net
Wow on that test the Brian Crowers fall up pretty short with the lowest power gains and had to be tuned with cam gears to even get good power out of them. The Kelford 272's had a good power gain and kept good drivability.
Ya going off of those tests, the Kelford's seem to yield very good peak gains with very little change in spool time or power delivery. After doing some research, it seems that my next valvetrain setup will be a set of Kiggly Beehives and some Kelford 272's.
1gdsm4g63 what cams do you plan to use and what kind of driving are you looking to do with it? IE: quick spool for fun on the streets or top power for crazy highway runs?
I'm currently running BC 280s and I do both the quick spool fun and highway runs. My turbo starts spool in the 3800 rpm and is never ending so I'd like to raise the redline.
Kiggly Beehive are the way to go, im using them on my set up. Had them replace the shit HKS ones
Im part of the beehive bandwagon myself. They have a lower mass at the retainer end allowing for better valve control. Also, they typically use a oval wire which allows greater valve lift before reaching coil bind and can use a lighter retainer due to a smaller diameter at the top of the coil. So, beehive FTW. :thumb:
Joe
SBR
I would agre that any beehive would be the hot ticket, for reasons already shown. Myself , due to a budget adn not having the need to rev past 8500 RPM i was just fine with the BC stuff.
I had driven a friedns car with the similar (same lift) cams but made by some one else with the same BC springs i now have and they are just fine for me.. But you are asking for BEST.. so along with the others BeeHive FTMFW!!!!!!!!
