420A Help! ATX seems to have died.
shades tinting
Oct 4, 2026
barrie, ON, Canada
Hello. I'm new to this site and was hoping for some advice.
I purchased a 98 Talon ESi for a first car for my daughter. This past week the transmission crapped out on me. It stopped going into any gear at all while it's running.
I would just replace the entire car however this one only has 110k on it and I've already put many new parts on it. I pumped out a bunch of the ATF and replaced with new fluid. Now the car will engage the reverse gear but sounds like shredding when I try any forward gears.
Does anyone have any advice on whether I can get this transmission back to good health or look at alternatives?
I'm not very knowledgeable but i do know the non-turbo 2G cars (barring the spyder) use parts pertaining to Chrysler. As such the automatic transmission (F4AC1/41TE) for the Talon ESI should use Chrysler ATF+4, any other trans fluid and there may be issues from what I researched. If you use multi-vehicle fluid you wanna make sure it is compliant with MS9602.
Did you notice metal shavings when draining the fluid? And could you get a video of the noise when trying to engage drive? Also did the fluid smell burned?
  • For sale 2g 2g GST auto trans case
    2g auto trans case. With bearing plate and end case covers. Good condition. Trans was like...
  • Wanted 2g 2g radiator support
    Im looking for a radiator support if anyone has one
    • Fundsm
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • For sale 4G63 Race parts.
    Brand new seal in box Kigglys HLA 175$Kigglys 12 tooth billet crankshaft triggel setup 250$...
    • GST2012GSX
