420A Heater Relay location
What’s not working? The blower?
Blower relay left kick panel under dash:
So my heater relay 10 amp fuse keeps blowing we're trying to get the AC up and running but it won't work so we're thinking there might be a short somewhere and we want to check the relays and figure out where the heater and relay is at
So for the AC button I'm not getting any power nothing's coming on and I cannot get it to actually run and it's just that 10 amp fuse that keeps popping on us
Okay so I finally found my relays however it's still having the problem the relays are good I did navigate through here and I found a site or a story or however you want to call it was having something along the similar same problem his problem was his ECU controller or computer is what I think it said he disconnected it everything would work with the fan running everything would turn on he ended up buying a new one and then it was working fine however mine does not get any power to it at all so now I know that it's also a possibility of being the switch I just got to figure out the switch see if it's good and then I got to see if that controller is good I may just replace both of them to be on the safe side the wires look good from what I could see anyways so I'm not sure if I have any shorts anywhere but if both of those are replaced and I'm still having that trouble then I know it's a wire and it's a short somewhere
If you have more spare fuses, unplug the ACCU and replace the fuse, see if it blows again. You can do this with all the components in that circuit to rule them out before searching for a short in the wiring.
Very true I am sorry on that guys not the best with that. But I have a 98 Mitsubishi eclipse 2.0 gs. So the problem is my ac/ heater won't get any power it blows the 10 amp fuse even when the switch is off. I don't know if it is a short in the AC computer or the switch.
All the relays are good so far. Just can't get power.
Unplug one or the other and replace the fuse, see if it blows again.
Just in case you don’t know, never replace a fuse with one that has a higher amp rating.
    • george bromwell
    • pma1123
    • Sdcryan1
