Headgasket
drpending on the surface prep..
If you are NOT milling the block, and head.. use a composite (Mitsu OEM or felpro)
if you have a fresh milled head and block then you can run an MLS (cometic)
OEM is recommended but if your over then most likely you'll find more aftermarket. Basically if your not sure of the head and block surface being perfect then run composite or organic, but if your pushing high boost and you had some surfacing done run a MLS Gasket instead. Composite should suit you fine.
