- Thread starter
- #26
Spoolin98
- 1,646
- 24
- Feb 1, 2004
Easton,
Pennsylvania
What's not to understand? You are trying to put 12mm studs in an 11mm hole. OF COURSE it's going to get stuck.
To answer your question, for the third time, YOU CAN use 6 bolt (12mm) ARP studs with a 7 bolt head (regardless of 1g or 2g, it's still 11mm), you just need to get the bolt holes bored out to 12mm. Trust me on this, I'm doing the same exact thing as we speak.
Ok, your obviously not understanding what I'm trying to say. I understand what your saying. I know I can bore the holes out. Ill try and explain this one more time. I took the head off the car, it was already on the car using the stock head bolts. So it was 7 bolt head already on a 6 bolt block, got me? So, if the stock head bolts on a 6 bolt are 12mm, then the holes in the head must already be bored out because it was previously on the car. Thats why I keep saying if I took the 12mm bolts out of the head to get it off, I shouldnt have a problem putting the head over the 12mm studs. Understand?
jk
