smoking need some help
n2orbit
298
May 10, 2003
smokes under boost, and if you rev it up enough for the bov to go off
compression was 150 across the board.
took the ic pipes off and oil was thicker in the upper ic pipe and in the intake where the bov goes back in.
i have been told it's the HG turbo seals, rings, or valve seals
its a 2g and the motor was redone and has less than 8k on it using the 4 layer metal gaskit but stock studs
oh yea the smoke is a white/blueish color.. there is no oil in the coolant
Please help guys i just wants this SH*T fixed
Sorry but I don't know if your question falls under Cylinder head and short block in advanced tech. And yeah turbo seals are probaly gone.
got under my car today looks like there is oil around the middle of the exhaust mani and some faint oil running down the block from there
