Head re-build
chris-tsi94
Jun 5, 2005
Puyallup, Washington
Ok this is it! its time to rebuild my head! :thumb: I just want some recomendations about a less expensive way to go about doing this. I want to get another 60- 70 horsepower out of this but dont know if I should go full porting and polish if I can just get it resurfaced and upgrade cams and valves????? Do I need to get my head ported to get the significant gain that I want right now? I am not ready for a stroker kit yet but am just trying to push my car into the high 12's. Hollar at me with some advice!!!!! ;)
The only way to get 40 or more whp you are going to have to put cams in. All the other stuff is good but to get some power cams is the way to go. I recomend 272/272 combo. People say its not that great because of the idle but you will see the best gains. Who cares about idle, and I think it sounds nice with a good exhaust
i would recommend ferrera bronze valve guides and seals, manley valve springs and retainers, a good valve job. just stick with the stock valves if they aren't bent as this would save you a couple hundred dollars. also if your looking for cheap cams i would go with the DKS 272's to save some money.
with the 14b there is no way you will gain 60-70 horsepower with a ported head and cams. with the ported head and cams your turbo will not be able to keep up with the air being ingested into the engine and you'll not be able to hold as much boost in the upper rpm range.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
