tranny needs re-build?
Alex Bland
666
3
Jul 2, 2008
Seabeck, Washington
ive been thinking it needs to be re-built because, i can pull it out of 1 and 2nd gear w/o clutch and put it back in. Also it has a hard time getting it gear from a stop, and reverse kinda grinds when i rev it and let it fall back down put in the clutch and put it into reverse it makes a little grind noise(before i start moveing). could i just be low on fluid?
my car has LSD in it
Make sure the linkage on the trans is okay, Mine did the same thing and I had one bolt come out and it was a bi*** getting it into Reverse and 5th.
Your sincros could be off.I can shift mine to all gears with no clutch but can not go back into 1st.But I am a truck driver and that is how we do it.
