mild re-build
airFS
98
Oct 9, 2006
Harrisburg, Pennsylvania
I was looking into having my piston rings and headgasket replaced and while the engines apart what else should I look into replacing? I was thinking some arp head studs, oem 2g pistons w/ rings, some sort of quality head gasket, and probably a new clutch and flywheel. I'm not after big power or some special number for my car, but I beat on it every day so I'm looking for it to be as reliable as possible.
When you replace the timing belt, go with an oem mitsubishi timing belt or a stronger one machv.com offers a super strong timing belt and if you dont want to eliminate the balance shaft they even offer a stronger balance shaft belt. Aftermarket belts sold at everyday parts stores such as advanced auto, autozone, or nappa just dont cut it.:talon:
If you havent done the timing belt and water pump, id do it now it would be a great time to do it.
According to the previous owner they were changed about 25k mi ago but I'm not too shure about the water pump. I was also considering having the balance shafts removed but Im not too shure about it yet. Please keep giving me other suggestions I want to do this right.
