420A having some problems with my Talon
DSMAdrenalinePS
May 6, 2009
New Berlin, Wisconsin
i have a 95 talon non turbo. It has no motor or trans. I am trying to get the drive shafts out and i cant figure it out. like i said the trans is out. what do i have to do to get them completly out of the car without cutting or breaking things. and obviously it is front wheel only
are these the front cv shafts ? if so you can just bolt some wheels on the front, put the weight of the car on them then use a impact or large breaker bar to remove the cv shaft hub nuts then disassemble the hubs & the shafts should be able to be removed from the hubs.
