have maft but there is only 2 nipples on the intake pipe?
jbark
115
May 11, 2008
Reading, Pennsylvania
so after buying a maft setup with upper piping and seeing 2 nipples i went ahead and got a catch can for the valve cover hose and put the charcoal and boost selenoid on the nipples. i have the catchcan vented now because i dont have a place to put the other hose and i think this is what is causing my weep hole to spew oil. where could i put the other side of the catch can to try to eliminate this oil comming out ### it is bad. and NO it is not a cracked valve cover and the gaskets are fine. i also rtved the shit out of the gasket. its only comming from the weep hole and i wanna fix this.
wouldt you know? that hole does go to the spark plug area. so my leak lies in there. thanks for pointing that out. i just check over the whole vc for cracks in that area and found none. and i rtved the spark plug gaskets so lets see if its fixed, jbark
i have my old one since the one i have on is painted. so i will see if the rtv did the trick and then i will swap the old vc if its still leaking. thanks, jeremy
