Half deaf..
'97boostinGST
1,102
Mar 1, 2010
Oxnard, California
I'm only getting sound out of my drivers side speakers and once in a while a slight static noise from the passenger side. I mean both front and back speakers do not work at times, is a wire loose somewhere that I should check?
My girls avenger is doing this right now..I checked the connections from the amp to the speaker and they were fine..But I forgot to check if it got fixed..It could be a loose wire behind the panel itself as well..
Still have stock head unit and stock amp.
I do have aftermarket speakers all around I'll check the connections on the amp as well as the speakers.
Thanks.
Make sure that no part of the speaker terminal is resting anywhere near the door. Also if you used aftermarket speaker plug adapters, the crimps can go bad or have poor connections .
Ill make sure to check it out..thanks!
