Hahn Compressor Housing
Yea thats what I thought would it be ok to take off with everything bolted up still. Did a boost leak test yesterday and its leaking there.
Be sure to use good snap ring pliers, if you use normal pliers you better duck and run if it slips.
You can just take the cover off if you can get to it bolted up. I believe there is a oring that goes between the cover and chra this may be your culprit, or some kind of crack in the cover itself.
While doing your blt, spray alittle soapy water and pin point the leaky area. After you find it make a mark with a marker, so when u remove cover u know exactly what to look for and where.
