GVR-4 GVR4-battery relocation
1gAWT
71
May 14, 2011
Lincoln, Nebraska
I'm getting ready to relocate my battery to trunk using the following diagram. I was hoping someone could explain how and where I put power to the fusible links. I circled it with black. I figured I would mount the plastic piece that sits on the positive terminal with four fuses in it and run power to it from the rear but from the diagram it looks like I have to run some power out of that but to where in the fuse/relay box is my question?
Thanks
Garrett
I've been working on a battery relocation for my 1G DSM. So it might be a little different than the GVR4. I ended up ditching the stock main fusible link (the 3 or 4 fuses right on the positive battery terminal) for two Bussmann fuse modules. I just mounted these right to the frame where the stock battery was located.
There is another wire, that connects right to the positive terminal of the battery, that goes over to an m6 screw that is under the sub fusible link. I don't have a pic with me, but I can post something after work. This is my setup right now, still being finished.
Here's a picture of the sub fuseable link and the black wire I have going to it. This wire stock was two 10 gauge wires going to the battery positive terminal.
    • Sdcryan1
