2G Ground for coil pack?
Nasty Dream
455
3
Aug 30, 2011
Alexandria, Virginia
I've read everything I could about grounding and 'where to' and such. I believe I have weak grounds that are causing some mild issues and so I decided to ground things like the alternator and engine with dedicated thick copper wire.
At least one person maintains that you should ground the coil pack as well. I'm looking at the coil pack and not sure where to ground:
The line is showing that both black pieces are the same part.
Can/should I ground the circled bolt to the firewall, then to the battery?
The reason I ask is because the circled bolt is really on there tight, and I don't want to break anything. I mean, I put quite a bit of torque on it, and it didn't budge; I'm a little worried about snapping it or something.
It wont snap just torque it out quick if your worried, and you don't need to ground it then ground to the battery one is good enough just make sure its a good clean ground, remember the motor and trans have 3 grounds total or so, ground it to somewhere on the motor and it'll be fine, what issues are you even having with it the way it is
If I helped you out a little can you bump my rep LOL
OK, the idea with grounding to the firewall first is because there are several grounds that would have to run all the way to the battery.
Instead of my throttle body, intake manifold, and coil pack each grounded all the way to the battery, I can ground them all to the firewall at the same point, then run 1 ground to the battery from that location on the firewall. Doing my alternator too.
> At idle, with the turn signal on, I can hear the fuel pump loosing a lot of juice in time with the blinker. My profile for details on that. May need to tear into the rewire and see if I didn't mess something up.
> I've taken so much stuff out of this car, I don't even think the original grounds are in place anymore. I don't think there is a ground to the transmission right now, only the one from the engine itself.
I don't know, aluminum is 59% less conductive than copper, and I think the distance is too lossy. I don't even understand why the trans needs it's own ground ... but I might as well give it a good one?
Basically, the car is old, I'm just making sure everything has a more than adequate ground.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
